Non car related, but anyways...
I need a cheap laptop to use for uni. Around the $300-350 mark, may spend a little more if its near there.
Needs at least a 15" screen. Usage will be internet (needs wifi), word processing, and java programming. Any extras will be a bonus.
Let me know what you got around that, and ill consider it.
Cheers. :thumbsup:
