Hey guys,
If Anyone has these parts in good condition I am looking to buy asap!
1x drivers side door electric window control plastic surrounds... As I snapped it :(
1x gear stick plastic surround with the cigarett door thingy.
1x plastic A frame drivers side as mine has some holes in it due to mounting boost gauge holders...
Please PM me with a price if you can help :) cheers
WTB: still after r32 gtr bonnet and grill....
ive got a gtr bonnet with a small golfball sized dent on the front left wine red. and could possibly let go of grill if it was all at the right price
After the following parts to suit r32 gtst
r32 gtst (or GTR) Drivers door - prefer black, in good nick
r32 diff - std one required for regency. I can shim it, so worn ones are ok
r32 gtst - tail shaft. One that runs from the gearbox to the diff, not the sub axles.
Have exams on this week coming, so can pickup anytime after friday.
Is this turbo back to cat?
this one is from turbo to front pipe only, full stainless very good condition.
i've just never found the time to fit it.
this one is the same, but it's for sale on ebay for $145
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
