I'm just going off what I've read - that all butterfly systems are illegal. Maybe it's only in some states. That said - if it were legal dB when fully-open, probably fine. I know some cars have these factory fitted - but obviously that's circumventing the issue.
A quick search picks up these threads discussing it. Mostly referring to Sydney, but yeah --
http://au.toyotaownersclub.com/forums/index.php/topic/26849-xforce-varex/
http://www.cruisingbrisbane.com/forum/topic/56629-xforce-varex/
http://forum.pulsar.org.au/showthread.php/88591-X-Force-Varex-Systems?p=1704456&viewfull=1#post1704456
http://www.nissansilvia.com/forums/index.php?showtopic=472819&view=findpost&p=6046258
http://www.viczcar.com/forum/index.php/topic,3593.msg37503.html?PHPSESSID=52b3f55a77d6450fe763de9a4a289b7d#msg37503
http://www.boostcruising.com/forums/index.php?showtopic=710055&st=0&p=1287175953entry1287175953
http://www.gtrydaz.com/forum/topic/adjustable-exhaust-valves-eg.-varex,-apexi-now-illegal-579138/
The last has an interesting comment - not sure how relevant in SA? I think EPA is national?
I'm not sure whether people are aware of this, but under part 19(1)(d) of the Protection of the Environment Operations (Noise Control) Regulation 2008 which commenced on 1 March 2008, it is illegal to have temporary noise reduction devices installed on vehicles. Part 19(2) provides 6 months grace, so this means that people can't be defected for noise control devices until 1 September. It is worth bearing in mind if you either have one of these exhausts fitted or are looking at fitting one in the future.
I thought it was to do with modifying the exhaust flow on-the-fly changes the emissions of the car? I could be off base though :whistling:
Interesting links there Jenna. And while noteworthy, I think an ECV is the LAST thing that most of us would get defected for :) .... but it would be interesting to see if you would or would not get through Regency with one fitted.
The apexi one is just a flange with butterfly valve in it yes? With a cable you run into the cabin? If so, as long as you hide the switch good enough, how would regency ever know it was there? Wouldn't it just look like any other flange in your exhaust?
looking for an r33 gtr pressure plate.. must have code 571 000 printed on it pm or txt 0401216575
I rang NPC and that number is a diaphram number and they need to know more specifics before they can match up a pressure plate
the bracket, and cable running off it going to the cabin somewhere would be a give away. As someone wise once said, they are assh*les, not idiots. From memory they even made someone weld in them silencer tips that you can remove to make it legal.
Looking for rubber pineapple mounts for the rear end of a r32. Got some metal drift ones in there that I'm really not Into lol. If some one wants them let me know. Also looking for the rubber strut tops for the front as one has completely deteriated. Cheers
Matt..
http://www.youtube.c...h?v=pBnhNFdH-Aw
Apparantly this noise is starter motor, car wont start at all :S
SO!.. WTB Starter motor lol! R33 S1 auto. Also will pay to have it put in if someone can come to Henley Beach just off Tapleys hill rd
call 0421 460 040
Edited by awsam
call 0421 460 040
^ NVM sorted
Considered one of those Dynomax VT mufflers? Unsure how well they work, would at least quieten it right down on idle.
http://www.dynomax.com/
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
