WTB the following;
Rb20 standard radiator for an r32
Passenger side r32 guard in any colour, cheap as its going on my track car and will not look pretty in a track days time.
Still after these, mainly the radiator though!
Hey guys, after a stock r32 GTST airbox and a reasonably quiet, good flowing cat-back as the after market gear on mine is driving me nuts.
Also would like a stock front and rear bumper preferably in white.
PM if you've got something.
