Coil packs to suit a RB20, RB25 Series 1 or RB26. Full set of 6.
Must be in good working condition. No misfires. No cracks anywhere.
Also, all coil packs need to have the little springs inside the boots.
Please let me know if you have a set available, and how much you want for them.
PM me, or txt me on 0434 030 114.
Thanks
Ray
Few Bits and Pieces to finish off my 33,
Centre Reversing mirror, Drivers side mirror cover (plastic triangle piece), Boot lining, All round lowered suspension, Drivers side Visor.
If you've got one of these laying around that i need, message me and well work out a price :)
Jordan - 0434 287 393
