Items:
RB25det neo engine package
Extra Info:
prefer complete engine but let us know what u got or if u know of one 4 sale.
from r34 or stagea (non 4wd)
Contact Details:
0411 758 793
Price and price conditions:
Preferably cheap! depending on what u got
need standard 5 stud nissan rims for R33 4 door rb25det trying to get ready for murray bridge autofest in january 08
can sme 1 please help me out pm-me or just call me on
(Allan) 0401409575
cheers if any one can help.
Items:
R33 Series 1/1.5 Type-M front bar
Extra Info:
No deep scratches etc (except under the bar is ok).
Would be great if it were Wine Red in colour but any is fine.
Contact Details:
PM or 0401 926 276
Don't be a hero like autotech imports (they wanted $350 for a piece of junk)
Items Wanted:
R32 gtst type M side skirts and rear pods
Contact Details:
phone: 0409098923
email: [email protected]
Whatever is fair
Pretty sure drinkies ( http://www.skylinesaustralia.com/forums/m13898.html ) still has a set,
located in Nairne, adelaide hills
Items: standard skyline(any) catalytic converter (CAT)
Extra Info: Any condition
Contact Details: PM me here
Price and price conditions: Can come pick up where in Adelaide. Preferably cheap or swap for a single bottle of booze of your choice.
Edited by vietorious
WTB: Trust Power Extreme II Cat back zorst! new or used... prefer alot cheaper than RRP.
or I wouldnt mind a Buddy Club Spec III............ or or something custom 3-3.25" stainless steel cat back through a hi flow muffler and out a set of flutes....
Anyone out there have a 320kph instrument cluster for a BNR34
or know where to get a cheap one.
Peter 0400 850005
pretty sure JMS has one dunnow what the price is, would say pretty dear
im after 1 as well... Nismo with white face is sexy (Nengun has it for around $600)
apparently the led light background is red or orange?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
