hi guys
anyone know if there is an aftermaket plenum to suit an r34gtt? im after one with a front facing throttle body.?
why dont the ones for r33 fit r34neo engines? is it only because of the fuel rail? what other mods would need to be done if any?
thanks
Justin
https://www.sau.com.au/forums/topic/144004-aftermarket-plenum-to-suit-r34/
They don't bolt up to the head. Completely different.
I have heard of an R33 one fitting with some new holes drilled into the head and some on the plenum but haven't seen it.
You could get a custom one for the top half only made up fairly easily.
There has been talk of a couple being available soon but soon just keeps stretching out into infinity.
Are you 100% sure, i havnt tried it, but only as i havnt had the parts at the same time, i am pretty sure they are the same bolt pattern, The injectors and fuel fail mounts are different.
OK now the greddy r33 plenum does fit the r34.. lets put that to bed now i have one on my car and no problems..
hey guys
1
im not saying anyone is wrong or wright here, (as i have no proof and havent tried this yet) but i find it hard to beleave nissan would change the bolt pattern on r34 to be differrent from r33, so can anyone 100% confirm the pattern is different or is it just what ppl have been told?
2
is the top half of the plenum the same pattern as r33?
3
IF IF IF the patterns are the same, all that would need to be changed are the fuel rail+injectors?
4
Mario, More info please!!!!!!! i know it sounds like a stupid question but are you 100% sure your engine is a Neo? if it is we know a greddy plenum will fit! please give us more info and photos.....i want a greddy plenum soooo bad so i can tidy up my engine bay.
so can anyone give a 100%confirmed answer for the top 2 answers?
thanks
Justin
theres a guy on the forum user name: 600hp who makes custom plenums for R34 GTT. very good quality and price, flow more/better than most jap name brands I was told. just send him a pm. cheers
Edited by Forged
you could always cough up the money for a RIPS plenum...but the greddy one does fit, you'll have to use the r33 iac and fuel rails iirc.
so the patern is the same and the greddy plenum will fit yaaaaa...
i hate to sound dumb or ignorant,(but i am a simple deisel mechanic) can someone post up a pics of the r33 IAC (idle air control valve) and an r34 one?
what about the traction control throttle body?
i would like to set up a Q45 throttle body is it easy to set up? eg electrical plug, how to set up tps?
thanks
Justin
Edited by walkoau
This 600HP plenum; does it retain all the R34 bits like fuel rail and injectors? Got a photo?
i believe itis compatible with the factory fuel system, with larger throttle body too. best to pm the guy.
cheers
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
