  • Replies 126
Seriously though, why did drift32sedan post get deleted - it didnt have anything offensive in it. As a close mate of mine I think its unfair how post like that are deleted simply because they state the truth.
Lots of you guys dont get what its all about and what the scene is and who the people in it are. They are just like you guys, enjoy driving there cars. You dont see us smirking and scoffing at track days and DECA days, but the moment drift is mentioned, you get a whole lotta people on here with the "yeah i tried its nothing special" because they cant drift properly.
Drifting is just as demanding as Track days, but the best thing about it is that to be successful at competition level, its not all about how big your wallet is.
Well said,
Some people dont know what drift is...
I agree with scotsman, love the sport don't like the scene!!
And yes i do know people in the scene possibly more people than you...
Who do you know Miss JUZ? Any Drift Australia Drivers? Any Super Drift Drivers? Two of my close mates compete in Drift Australia and they are heavily involved in the Melbourne Drift scene.
Mega Power Is one of the most upcoming drivers in Melbourne and competes in Super Drift so Its safe to say hes got 10 times more of a clue than you do.
Getting sideways out of Noble park maccas doesnt count as a drifter.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
