hello,
i want to put rb26 pistons and rods in my rb25 block leaving rb25 crank. As i know rb26 piston have ~ 2mm lower pin location and CR of such conversion will be to low -- lower than 8.5. What can be done to leave CR in between 9-8.5?
Edited by Stronzo
to deck 2mm fron the block -- yes that`s the only way i was thinking about. I want to use rb26 pistons as they are stronger than rb25.
p.s. Well maybe if i can find neo 25 pistons -- i can use them. But they are still weaker the 26`s.
The RB26 runs a bigger stroke and same sized rods as the rb25.
For all that to fit within the rb25's deck height (which is the same as the rb26) they run a piston with a lower pin/compression height.
There's a bloke here in Adelaide that stroked his rb26 out to an rb29 using a destroked (machined) rb30 crank, rb26 rods and custom pistons with a very very small pin/compression height.
NEO pistons will lower your compression, once again why? Aftermarket rb25 forgies are getting quite cheap, and depending on your power level, probably unnecessary, stock pistons are good for 300 rwkw at least safely "IF TUNED CORRECTLY"(NISMOID did your car havee stock internals?With 350 rwkw)
But the stroke is controlled by the crank. The stroke is twice the offset of the big-end journal from the centre of the crank.
If he uses a RB25 crank, he will have RB25 stroke. If he has RB25 stroke, then he has RB25 C/R.
I think you have missed what I was getting at. ;)
The Rb26's pin height has been setup as such to suit the stroke, rod length and the blocks height.
If he were to use an rb25 bottom end with rb26 pistons (with their lower pin height) he WILL have end up with a lower static comp and very much less than ideal deck clearance.
i`m back again, thank you for your replies, now i`ll answer your questions:
why i want to use _stock_ pistons (not forged) -- because here, where i live we sometimes have +35 C in summer and -35 C in winter. Forged pistons are pain for a street car with low to moderate power output (imho) and are nearly impossible to use at winter :). that`s why.
what`s my power goals -- 350+. no more than 400 hp at the flywheel. i think it will be enough for me :). In Russia in Far East region where 95% of all cars are used cars from Japan -- experienced skyline tuners say that can be acived at 26 pistons only.
why i don`t want to use 26 crank -- it`s quite expensive if i buy it new and hard to find it in good condition if i buy it used.
The reason i`m doing this -- i mesured compression in my rb25det neo, and it is: 12-12-11.5-10.7-11-12 -- i`m not happy with it so i`m thinking what to do next. i have variants:
1. try to fix my current engine (not interesing, and hard to order parts before disassembling motor)
2. buy 26 motor -- i have a cheap proposal but it has no documents and hard to understand what is inside of this motor. and there is much job to install it.
3. build a mega-motor from my old rb25de -- install oil injectors, good pistons, turbo -- etc. this is the most interesting but i think the most expensive variant.
so now i`m desperate -- i can`t make a decision :mad:
Edited by Stronzo
  • 4 weeks later...
ok, got rb26 crank, pistons and rods at yahoo auctions. no way back :D
Can anyone tell me what CR i will have in a combination of:
rb25 block and head
rb26 pistons, rods and crank
stock head gasket
As far as i know CR will be slightly higher than 8.5 as rb25 combustion chamber is smaller than rb26. rb25 cc volume is 62-64cc, what about rb26?
RB25 std everything is around 8.5:1 (31.3mm comp height, 72mm stroke, 15cc dome)
RB25 w/- RB26 pistons is around 7.8:1 (30.3mm comp height, 72mm stroke, 15cc dome)
RB25 w/- RB26 crank & pistons is around 8.7:1 (30.3mm comp height, 73.7mm stroke, 15cc dome)
this is working on both heads being at 64cc and 1mm head gasket, I measured a 26 head on Thursday and it came out at 64cc. It will vary slightly depending on the dome volume and the head gasket thickness.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
