HKS Super Drager cat back system
Original HKS drager for a R33GTST or GTR as they share the same part number from the HKS catalogue.
In good condition, purchased second hand from SAU forums but never installed on my car. Unit has some scratches underneath main muffler.
$ 450.00
Trust Blow Off Valve Type-R
In good condition, purchased from SAU forums, ran it in my car while I was running high boost pressures (15psi+).
$ 200.00 SOLD
Defi BF Gauges and unique Border R33 GTST/GTR Shroud
In near new condition Defi BF Turbo, Water Temp and Exhaust Temp 60mm Gauges. Used for no more than 2000km. Includes individual gauge holders but does not include loom or sensors and the control unit as they are still installed on my car. These can be ordered as spare parts through any Defi dealer.
Very rare gauge cluster is made by a Japanese company "Border" basically brand new. This is for all model R33GTS/GTR, it looks part of the dash as it sits on the passenger side pointing towards the driver. Very Cool!
$ 450.00 Gauges are no longer for sale! Cluster is still available $100 SOLD
Located in Melbourne.
Please contact me via PM.
Edited by ChrisR33GTS-T
https://www.sau.com.au/forums/topic/144853-r33gtstgtr-hks-super-drager/
waht does the bov sound like...a whoosh or a flutter?
The BOV really only operates at high boost pressures even on the softest setting, so normally when you change gear early you'll get a bit of a flutter or a full woosh once the turbo hits full boost.
did the previous owner say if the exhaust was loud or quiet?
I heard the exhaust on the prev owners car before I baught it and it had a nice gurgling rumble. Even tho its basically a 4inch exhaust it has three mufflers so its never going to be loud.
thanks for the feedback Moonus... HKS of course don't make these exhaust systems anymore so they are becoming a sort after item.. It took me ages to find this one and that was over 12 months ago!!
i have HKS super dragger on mine with BAMBTL's dump and high flow cat and it sounds very nice at idle it's reasonabley quite but as you really start to open it up it comes to life (While still not being to loud) i have had a heap of people comment on the how good a note it gives off too.
oh yea it flows well too :mad:
Just letting the VIC guys know I have a few interstate buyers who are keen but VIC guys have first preference due to the inconvenience of shipping the exhaust interstate. I'll give it till 03/12 (End of Day) then i'll ship it interstate.
Regards
Chris.
Does the BOV have the strong or standard spring?
Also does it need an adaptor to fit to a standard pipe? If so does it come with it?
Edited by DivHunter
BOV comes with the standard spring. When I baught it i thought it has the stronger spring so i purchased the softer spring from nengun but found that i already had the softer version! This bov is capable of holding 3 bar (with the stronger spring i assume) and is commonly used to replace the two standard GTR bov's, so its meant for cars making big power. If you use it on a stock turbo you will just get a whole lot of flutter.
This BOV does not come with any adaptors for any cars except for GTR. As per www.trust-power.com
Updated pics with the gauge cluster. Also I'll seperate the cluster as i'm having second thoughts about selling the gauges.
$ 150.00 for the cluster (in near new condition)
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
