just installed a new turbo on my RB20. the latest problem is a slight oil leak i cant get rid of, coming from the oil feed on the turbo side. iv tried new washers and material washers. And it still leaks so slightly. The bolt is a banjo bolt.. has any 1 had this problem before?
https://www.sau.com.au/forums/topic/145010-turbo-oil-feed-leak/
what type of turbo did you install? is it oil cooled only?
if so the oil restrictor needs to be changed as ball bearing units need less oil than plain/journal/oil cooled only, so you need to adjust the restrictor
Other people have wrote on this forum that it needs to be super tight, so use a breaka bar and use plenty of leverage and tighten the sh1t out of it.
Do a search on anneal, you may come up with something.
Essentially you use a gas torch or your mum's gas stove to heat your copper washers to a cherry red colour and then drop them in cold water.
I'll see if I can find my diatribe on this topic and add a link.
Go here:
http://www.skylinesaustralia.com/forums/in...4&hl=anneal
Also I agree with Grigor, you use a breaker bar and you risk stripping the thread in your turbo housing, then you will be up that creek and in that barbed wire canoe and not a paddle in sight!!!!!!
  • 13 years later...
Related topic but I'm not using banjo bolts, using stainless steel 7/16 -24 inverted flare.
I know this is pretty basic but im having trouble sealing the turbo oil feed fitting 100%, its not leaking leaking but after a drive there is a small amount of oil around the fitting half a drop or less you can see slight discoloring.20201004_145114.jpg.db3939fc2e7db3c3dd4add355d61d5f9.jpg
First time, I installed it was worse the fitting leaked slighty so removed and found a small bit of grit in the thread cleaned and reinstalled was much better. After a few drives i found again a smaller amount of oil around the fitting, this time removed cleaned and reinstalled a little bit tighter then before and it was much better but again a very slight amount of oil (less then before) (above pic) around the fitting.
has anyone else had trouble installing a stainless steel  7/16 -24 inverted flare.
How tight are you suppose to tighten the fitting?
Or anything else i can try?
Edited by dyl33
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
