Turned out Nissan gave me the wrong size roll pin. *insert cursing here*. Anyways new pin sorted, box is all nice and clean and ready to go back in this week. I have never driven the car with ATTESSA functioning, shall be interesting :ninja:
attesa is the best thing invented...........
Just an update, box is back in. What a struggle to lift that thing and get the right angle!! We spent allot of time sweating it out in the pit in the heat. I really recommend no less than 3 people to put it back in unless you've got a gearbox jack or a hoist available.
Anyhow, I shall bolt up the rest and hopefully have some launching action tomorrow :cool:
Happy new years people!
Ok first thing, ATTESSA is farkin awesome! First day I get it back on the road and the rain is pouring here, can't believe the traction! What a blast to drive :wave:
Anyways almost everything is sweet, the only issue is I have remaining is a random clicking noise from the resistors in the boot that are positioned inbetween the rear lights behind the trim - any ideas what these are?
Edited by Remix-
