Ok so I finally have an RB25DET sitting in the garage waiting patiently to be installed into the ceff... The wrecker I bought it off had reason to believe it had been sitting for maybe a year, some of wich was outside not under cover. It's also unclear to me if the engine was properly sealed i.e inlet and exhaust plugged up.
When he first did the comp test the engine was hard to initially turn over, then showed some irregular results 145-165.
After a few more rotations it showed 165-170.
My questions are these-
Is it likely that there was some form of corrosion build up in the bores from having the engine sit unused for so long? Will this burn off without any harm to compression? should the engine be 'free' enough to turn by hand?
not good if rain was getting inside the engine, but if the compression numbers are up around where they should be, it must have been fairly well protected. how bad is the corrosion on the motor?
Pull the motor down
Only way to tell.
If it's corroded, it's a bad engine, basically, throw it away.
My uncle bought a 1UZFE and couldn't bore it enough to get rid of pitting that the water did to the engine.
I'm not really worried about actual water droplets getting into the engine... More so that it was left to 'breathe' if you will. There is a little bit of that white chalky corrosion on the aluminum parts like the inlet manifold and front cover on the turbo.
What would the reason be for the initial comp test yeilding bad results, and the second one very good results? Crud around the top of the piston and rings?
Am I worrying too much? lol
was the compression test done with the motor hot? compression tests cant be done on a cold motor as the readings are inaccurate. has to do with the expansion of the metal rings, pistons and block. May be why the results varied....
initial ones prob had no oil presure, then slowly as it built it got more *relative* if you will, either way i bought an rb20 in such condition, held just under 200rwkw awsum compresion, unless there was actual water in the bores and left to fill up/sit there with it in, i doubt you will have much troubles.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
