Been on here for a bit not never got around to posting up, I'm from SA obviously as thats why I'm posting in here. I own a Jet black 1988 HR31 GTS-X, with an rb20det Silvertop conversion.
Specs are -
Stock silvertop with 3" dump / Front Pipe, into a 3" system with a decat pipe, mandrel bent.
K&N pod..
Stock SMIC
Had an o2 Sensor fixed as it was running like crap and it pulled 126.5rwkw on 8psi (stock boost) without the decat pipe.
Rolling Stock - 17x8 17x9 Koya Drifteks powdercoated white. 225's and 235's.
Has standard suss with lowered springs in front n rear, as I got it it had complete aus del front end and ive changed a few things to make it jap once again, car was painted inside and out around 5 months ago.
Have also put on the original stickers that it came with from factory as I thought the black needed a bit of contrast, interior is standard, just put in a boost gauge...stereo is basically standard too.
Will have some serious power lined up for it soon + a new clutch as mine slips on boost when its nice and hot outside. Pics below:
Pic before drifteks ^
Recent pics
Dyno read
and one vid of the gts-x at a local motorkhana.
http://s103.photobucket.com/albums/m137/dr...otorkhana33.flv
Cheers for looking fellas.
Ev.
Edited by evsr31
https://www.sau.com.au/forums/topic/145258-new-member-hey/
hey buddy thats 1 solid HR31 looks teh sxc
welcome aboard and enjoy your stay
i recon im due to see Brad soon also starting to get a little hard to make a fast shift to 2nd no slipping as yet though any gear under full boost so i guess ive got a while if i dont go silly
https://www.sau.com.au/forums/topic/145258-new-member-hey/#findComment-2715352
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
