Hi
as u might know im looking for a GTR R32 but while i have been looking around ive come across a nice 1992 Twin turbo Toyota Supra. Jus wondering wot u guys think of them?
What are there performance lik compared to R32 etc etc
Edited by Adz2332
  • Replies 65
yeah, itd be a JZA80.
first things first, theyre pretty heavy mofo's, so they can be a bit boaty (2 of 3 that ive driven have had stock suspension, shocking stuff, the other had tein coilovers, massive improvement...)
they dont like to rev like the GTR's, but its much easier to make huge amounts of power from them.
theyre very comfortable on longer trips, takes a bit of effort to get in and out of, you sit in them rather then on them, if you get my meaning.
theyre thirsty, and theyre not the easiest things to drive in the wet, but all round, theyre great cars, and i doubt youll regret buying one.
The 2JZ engine was in the 1993 - onwards (the 96/97 + models came with VVTI i believe). It can be either NA or twin turbo. The main difference is the power and the weight (if you are comparing to the R32). r32 gtst has 160 kws and 290nm torque? , where as the JZA80 twin turbo has 206 and 430nm torque. But the supra weighs a lot more than the gtst. 0-100 in the supra is said to be about 5.6, where as the gtst is in the low to mid 6's.
Both engines are durable - strong internals, revvy. Supra twin turbo in manual comes with an extra gear. But down sides, supra has no space at hte back. The r32 i think has more space in the back.
EXCELLENT GUYS. Does anyone kno wot the model letters mean lik supra SZ or RZ?
if the car youre getting is an RZ or an SZ its a'93-'02 (JZA80). anything before that (to '86) is the JZA70.
afaik, RZ denotes the turbo/twin turbo models, and SZ is the non turbo.
Edited by scandyflick
if the car youre getting is an RZ or an SZ its a 93 onwards.
So i should be looking for a RZ 2JZ engined Supra??
I have had a look at 3 cars so far, would these figures i have be about right for each car?
1993 Supra 13.1 1/4mile 320hp standered
1989 GTR 13.0 1/4mile 280hp standered
2000 WRX 14.4 1/4mile 227hp standered
*Standard...
forget the rex. glass gearboxes arent cool.
the supra has the advantage of being newer, and being able to make power easier than the GTR.
the GTR afaik is lighter, has the advantage of AWD, and is just plain cool. :)
Yup, look for a JZA80 RZ with the 6 speed manny.
jap spec RZ is only 280hp - but this is disputed (similar to the gtr). US and british spec RZ is at 320hp
Better to go with the RZ - should you wish to do mods to it. SZ is ok - but when it comes to mods, you are restricted imo - and installing a turbo is not as easy as it sounds (or so i hear)
not to mention they got steel wheels on the turbos... *sigh*
Also to mention that PARTS as in modifying parts are alot more expensive, as there isn't as big of a damand for them as there is Nissan parts!
I thought of getting a Supra before i bought my 33! I am thankful for getting the 33!
Edited by Deluxe
but the flip side to that is that you dont need to open up the engine when you start chasing big horsepower like youd have to with a nissan engine.
But i hear nissan GTRs r hell exspensive to fix! Supras r much cheaper for every day parts? this true
try to get your hands on the special issue (i forget what number it was, but it had a pic of a blue s15 in the front) of speed magazine that gave mods for supras - that will show you roughly howmuch u can spend on mods depending on the different stages.... plus it had comparisions of the rz, gtt, s15 and rx7 as well....
just saw this while searchign for the issue of speed that had supras in it:
any car is expensive to fix where parts are concerned - best to get one where parts are plentiful
In the comparisions of the rz, gtt, s15 and rx7 which did they believe to come out on top?
Is it a new mag will it still be instores?
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
