I've just found out my wife is pregnant with our second child so am considering selling my car for the right offer. I've spent over $40K on it this year alone and could do with getting some of that back before the new bub arrives next year.
It's a 1999 V Spec - 50,000km's - however it's currently done less than 500km's since a full rebuild including new block, rods, pistons, crank and balancer.
The car has been set-up specifically designed to be fast as it can for tarmac rally / touring rally / circuit racing. Pretty much other than a carbon-fiber prop shaft it has exactly the same goodies as the famous Mines R34 GTR including turbo's, cams and diff's.
It's currently making 362rwkw's @ 25psi on pump fuel (BP Ultimate). I'm the 2nd owner and have had the car since mid 2003. I'll consider offers around the $100K mark.
Mods include:
Engine
RB26DETT
Aria Forged Pistons
ARP Rod Bolts
Eagle Forged Rods
Tomei Metal Head Gasket
Tomei 260-9.15/260-9.15 intake and exhaust Poncams
Tomei Fuel Pump
Racingline Adjustable Cam Gears
Ross Tuffbond Harmonic Balancer
Sard 700cc Injectors
Apexi Dual Intake Pods
N1 Oil Pump
N1 Water Pump
Apexi Front Pipes
Blitz NUR Spec Exhaust
2 x HKS 25/30 Turbo’s
Trust Intercooler
Race Aluminum Radiator
Serck Oil Cooler with remote filter
Racepace Catch-can.
Handling
HKS/Dynamic (UK) remote reservoir racing suspension
King Springs
Whiteline Heavy Duty Sway Bars (front and rear)
Racepace custom upper control arms
Nismo Lower control arms
Cusco castor rods
Pineapples
Hicas Lock Bar
Driveline
Getrag 6 speed gearbox
Jim Berry Custom Twin Plate Clutch
Racepace modified Attessa system
Nismo 2 way rear diff
4.111 front diff
Wheels and Brakes
Rays Nismo LMGT4 rims (Bronze 18 x 9.5)
Toyo R888 tyres (255/40/18)
AP Racing CP5555 6 Pot front calipers
375mm Alcon Rotors – Ferodo DS3000 pads
Brembo Rear Calipers
DBA 4000 Rotors – Comp 2 pads
Cusco Master Cyliner Stopper
URAS Competition Handbrake Shoes
Electronics
Autronic SM4 ECU (including Launch Control, Anti-lag, Flat Shift etc)
Autronic R500 CDI
Nismo MFD
HSK EVC 3 Boost Controller
Raceworx Attessa Controller
Orange TPMS
Interior
Nismo 320km/hr Dash
Nismo Titanium Gear Knob
ERG 4 point harness
Eclipse CD/DVD player
Boston Rally Splits
https://www.sau.com.au/forums/topic/145478-r34-gt-r-v-spec/
As someone with two young one's the second is a lot cheaper. Keep the car, I reckon that you will regret selling it, and you probably won't get a chance to get another like it till the kids have moved out.
https://www.sau.com.au/forums/topic/145478-r34-gt-r-v-spec/#findComment-2721658
Congrats Andrew, hope it all goes well for you.
with the spare money you have from selling the car, purchasing a new one and spending money on the bub i hope you've had some financial planning and that u have money working for you
https://www.sau.com.au/forums/topic/145478-r34-gt-r-v-spec/#findComment-2722771
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
