hey all,
i bought myself an eclipse XA4000 amp 2day. went to install it and it seems as though 1 channel isn't working properly? the car had a 4 channel amp in it already so all i had to do was swap over the amps. put in all the wiring etc and it seems the "left" channel dosen't want to work. whichever front speaker i plug into the left channel, it won't play at full volume. the other speaker will play at full volume and obviously drowns the other out.
is there anything else i can check? it definately seems like it is the amp. very annoying. it isn't settings in the head unit either because i disconnected the battery to install the amp. (settings reset)
so yeah... not h/u settings, not settings on the amp (frequency etc), i've swapped both speakers over and whichever speaker goes into the "left" channel it will only play on low volume. any help is appreciated.
brendan
https://www.sau.com.au/forums/topic/145511-amp-install-1-channel-not-working/
yeah i've swapped RCA's over etc... swapped the front speakers onto the rear channels and they played fine. had the sub bridged on the front 2 channels, didn't want to work at all.
it is weird though, because i am sure all amps are tested before they are sent out for sale? unless damage is done in transit through rough handling?
i've taken the amp back anyway and explained everything to him. he'll get back to me monday morning. thanks for the help anyway.
just thought i'd update what's going on.
took the amp back and they hooked it up all fine so it isn't the amp. they had it hooked up for me to hear and everything.
i've just put my whole car back together it seems. ripped the rear seats out and checked wiring the whole way along up to the head unit. checked behind the head unit etc all seems fine. no wiring is loose or anything.
taken the left door trim off (since it's the left speaker not working) and checked wiring... all seems fine.
so, my next guess is the left front speaker is blown? i swapped the +/- over on the amp etc just incase i got them mixed up but no change in volume. i'm guessing this because no wiring is loose or disconnected.
any thoughts? they are pioneer splits, brand new from the same place. they were installed bout 2 months ago? they are the TS-C1625 splits
Edited by white33gtst
You said up top that you tried both front speakers from the left channel and they were both low in volume, so that means that your speakers are fine right?? The amp tested fine at the shop aswell, so it doesn't seem like they are the problems, its further up the chain.
Tried a different set of RCA's?
Maybe its your headunit RCA outputs, try running one RCA at a time to the amp (and split the one RCA into the two inputs on the amp, you'll need a splitter). Try it on left channel, then right channel and see if there is a difference.
Fixxxer :(
hey
yer i had the same prob just last week all it was for me was the {rca} plug was stuffed so if u get a new rca plug and still not working try new speaker wire from your amp to your speaker cause there might be a short or wire is broken
so if still not working take it to a car audio sound shop
l8ers
all fixed. was the RCA's. the rca's were plugged in wrong in the back of the head unit, so the place i got to install my headunit stuffed up. they mixed the non-fader up with the rear set of preouts, so the sub wouldn't turn up at all on the headunit. probably shouldve checked that earlier but i was more worried about the speakers not working properly.
thought i would get it all installed by a pro in the skyline because i didn't want to skimp out on the quality... obviously ill go back to doing all my own installs.
so yeah, i've switch that around behind the headunit and all works well. thanks all
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
    • OR, Tell the Motec to STFU, you said shift, so try shifting! But then yes, I agree, more sensors needed to. Put either a wheel speed sensor, or a diff speed sensor on it. Then get an input shaft speed sensor too. (I say input shaft speed, and not engine RPM). This way, you can now also log and see if the clutch is slipping (RPM, vs input shaft speed), and you can calculate gear (Input shaft speed / Output shaft speed). At least then if the gear position sensor fails you have a backup. And realistically, the Motec should only worry about what gear you're in for the parts where I'm assuming you have some power management strategies in it for the lower gears. (IE, lower boost, maybe different throttle curves, different ignition curves, etc etc). But it should stop it shifting. Pull the flappy, that f**ker should just attempt the motion! Heck, even on a sequential like on a motorbike, you can keep trying to kick it up a gear all you want, the physically part of the box takes care of not being able to loop the whole way around the box! Only part you'd have to worry is how it gets to reverse.  But that's on the driver... An R32 shouldn't be so smart as to try and override the driver on a gear shift
