Hey all. I bought a 27mm front sway bar from SK as part of the group buy, had a lot of drama's putting it in since the bushes supplied didnt fit the bar so i had to use the stock bushes. I mounted the bar up on the medium setting and i have found it to be too stiff, so now i want to put it on the softest setting and its bloody hard to get the pin in there since the pin and the blade aree now at extreme angles.
took me around an hour and several pry bars to get the pin in.. this is with the wheel off and a jack under the LCA on both sides to take the weight off the bar itself. in fact i tried several different ways and its all too bloody hard.
pics
see what i mean... is this right? cause it doesnt look right to me.
Whats the go
On the hardest setting on the swaybar the pin is vertical
Edited by simon-ae86
https://www.sau.com.au/forums/topic/145593-swaybar-problem/
You really need to use aftermarket links which have a longer threaded section which means you can adjust the length. Its important to maintain the arm parallel to the ground so you really need to be able to adjust the length of the arm.
The bushes on mine were a pain in the ass as well. I found it was easier to just mod the saddle by opening it up a little so the bush can still be used but not such a ball ache to install.
https://www.sau.com.au/forums/topic/145593-swaybar-problem/#findComment-2721475
lol ball ache. yes i had that X 2
tried opening the saddles... to the point where the bolt holes wouldnt line up and the damn thing still wouldnt fit with the bar in it. I think i got the wrong bushes plain and simple.
question is. are the links suppose to come with the kit or is that extra? The rears came with links and they work a treat!
It would be pretty average if i had to pay extra for links-
https://www.sau.com.au/forums/topic/145593-swaybar-problem/#findComment-2721587
The softest adjustment holes are a bit of a stretch, that's normal.
The pictures are taking with the supension at full droop.
The stretch isn't as great when the suspension is at normal ride height.
:dry: cheers :)
https://www.sau.com.au/forums/topic/145593-swaybar-problem/#findComment-2724081
SK: acctually the pics were taken with the susp at ride height, i had a trolly jack under each LCA (you can see one in the bottom LH corner of the 2nd pic) jacking the susp right up until it was off the axle stand.
DJR: wish mine were that simple
https://www.sau.com.au/forums/topic/145593-swaybar-problem/#findComment-2725077
  • 3 weeks later...
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
