Ferni,come to a renew/saunsw track day at wakefield park to see some bloody quick rx's. Maybe the GTR driver needs some leasons,,,what did he say "these speeds are scary".
Neil.
Yeah i wish there were some fast ones down here. I like the Series 6's - doesn't everyone. Just haven't seen them perform like i've heard they can. I know of a few people with them, all to scared to track them.
  • Replies 42
The MCR R34 had too much power for the touge stage, The RE RX7 is a fully striped out thing with a basically standard motor.
The MCR R34 will totally decimate it around a circuit
Not true mate.
The RE amemiya FD has run a 58 or 59 seconds around tsukuba, with stock turbo's... not far off the MCR car.
Not true mate.
Not far off around Tsukuba is good enough because heaps of different cars are separated by poof tenths of a second but on more free flowing track i think itll be very far ahead
Edited by nismo 400 R N1
I agree to a point, but I think we have different opinions on what defines 'decimate'.
I think it would be a close run thing. And I'd imagine the GT-R would be quicker on the more flowing tracks, it's where the power makes the difference, but not miles ahead.
I personally think the RX-7 is a better handling car, but to each their own.
i believe its fair to say on a course like that....its very unfair for the gtr. that whole course had tight turns and hardly no straight full accelleration points.
i believe a r34 gtr will destory any type of rx7 on the perfect circuit, with tight turns long turns long straights and short ones aswell.
the rx7s biggest weapon is its handling.......on a course like the one touge
http://mugenpower.net/rx7c/ricesp.mpg
Right click save as
Very quick for what is largely a stock car on street tyres. Cool vid too.
Not true mate.
if u dont mind me asking wher u get that info from im loking for tsukuba lap records of some tuner company cars.
thanks
mark.
So a general R34GTR Vs "any" RX7 - Okay...... SP RX7.
So a perfect circuit, tight corners, short straights, long striaghts, and long turns..... "The RX7's biggest weapon is its handling"......... The GTR would be far superior than the RX7 in hard launching, thats it mate. After that. the difference is driver error for cars equally modified.
The FD RX7 won 12 hour races x3 at Bathurst in a car which included facotry A/C still fitted.... I suppose Bathurst isn't a real race track.
Please, dont just jump on the band wagon. You know jack about RX7's.
This course has another advantage for the fd3s: it is a downhill race.
http://www.youtube.com/watch?v=5KtOMR6csSc
There is a down hill and a uphill run ?
When it boils down too it, both cars are legends, both cars are major racing winners.
No, both battles are downhill, which evens out the fd3s' power disadvantage to the godzilla. R34s are good for their power and performance, but on a course with lots of sharp cornering involved, it won't have much space to do anything.
As Andy has said, both are excellent cars with great track records with their own strengths; an fd3s will dominate on some tracks, and an r34 on others, given equally skilled drivers.
in the 4 car battle I did notice a few things. The silvia was as hard tuned as they get. full sequential box, 520hp GT spec engine... hmm both the GTR and Supra were road cars and the FD was just a 'boost up' level of mods with a measly 380hp. to cap this off the silvia was the lighest car of the lot. if anything else had one Tsuchiya would have had to retire from racing...
Wouldn't you guys call it even and no advantage. RX7's superior handling chassis vs GTR's mechanical grip advantage using ATTESSA ?
Not on a Skyline forum where a skyline has lost...
:P
markimak: I got that Tsukuba info from memory. I haven't seen a list of record times, just from what I've read in various magazines and on DVD's.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
