hey guys. wondering if anyone can help me out. i have a 1996 series 2 r33 skyline. me and a mate changed over the front brake pads just before. now it was our first time on a skyline, so we did it slow and all went well. it was all good until i started it up... and the brake pedal is way soft, i can push it to the floor and the car wont stop! so we topped up the brake fluid thinking that would be the problem. but no, ive tried to pump it a bit, and it seems to hold some pressure after 5-6 pumps and starts to brake. but next time i need to brake, there is nothing. ive left the car sit for a hour, drivin it for a hour, and nothing!
what could be the problem? im using the dam handbrake to stop now!
any help would be great.
thanks.
https://www.sau.com.au/forums/topic/145777-brakes-not-working-at-all-o/
thanks.
you need to bleed the hydraulic system,
^ Exactly, Bleed your front AND rear calipers,
There are nipples on them that you undo and it will let any air bubbles pass.
I'm sure there is a article on it somewhere, just have a quick search.
Cheers
Josh
the nipples are the lil dome's ontop of the calipers. get your mate to pump the pedal up and then hold his foot down on the pedal then you open the nipple. just dont let your mate go all the way to the floor then repeat this until the brakes return + dont let the reservior run out of brake fluid. For f**k sake dont drive a skyline without brake's jesus!
Edited by dead32
who in their right mind would change pads without bleeding the whole system anyway its part of changing the pads and if you didnt know this you shouldnt have even attempted changing the pads
You bleed the brakes every time you change pads? I must be doing it wrong as i've never once had this problem and I only do brake fluid when it needs it.
while ur at it get some high temp fluids in. good for cruise and track days.
You mean - high priced fluid which is 100% more expensive for maybe 5% better performance... yeah thats a great idea.
Anyway for the original post, you have got air in your brakes somehow. Air bubbles are a pain in the ass to bleed out sometimes and sometimes you can make it worse if you stuff up something. You can spend a good amount of time getting the brakes back so if you cant be bothered take it to the nearest brake place and get them to use their pump. Costs an hours labour.
You dont bleed brakes wen u change pads, and it isn't part of the service! trust me I was an advisor.
If u need to bleed your brakes everytime u change ur pads then something is wrong with ur system.
Cheers
Josh
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
