SkyKC Posted December 4, 2006 Share Posted December 4, 2006 Hi, I have 1994 GTS-4 non-turbo, on the dashbord below the spped meter there are tow LED's one is "Slip" and the other "4WD", wehn I put the gear to 1 or two and rev more than 4000 Rpm "Slip" LED idicator turns on. Does anyone knows what that means? Does it means the clutch is slipping? means the clutch is worn out? I got no Idea............... Please guys.................help me Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/ Share on other sites More sharing options...
Eug Posted December 4, 2006 Share Posted December 4, 2006 its for your attessa, that i am sure of. i wont pretend to be cluey about it, but i have read a few threads about it. so a search might yield some results Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2726129 Share on other sites More sharing options...
chicane Posted December 9, 2006 Share Posted December 9, 2006 Are your front and rear tyres the same size? Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2737748 Share on other sites More sharing options...
SkyKC Posted December 9, 2006 Author Share Posted December 9, 2006 Are your front and rear tyres the same size? yes they are same size........ Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2738026 Share on other sites More sharing options...
IanB Posted December 9, 2006 Share Posted December 9, 2006 id hazzard a guess at it meaning you have slip on your wheels and its moving power to the fronts. Does your FW Tourque gauge go up at all? Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2738431 Share on other sites More sharing options...
R-SPEC Posted December 9, 2006 Share Posted December 9, 2006 (edited) its got nothing to do with your clutch. totally normal SLIP display: (active lsd fitted display) this display will show when the ignition is ON and will flash when the vehicle is traveling over a slippery area. ps. it also comes on when the car loses grip/traction. Edited December 9, 2006 by R-SPEC Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2738438 Share on other sites More sharing options...
Undiscovered Posted December 13, 2006 Share Posted December 13, 2006 Also, last I checked (correct me if I'm wrong), but all R33 GST-4's are non-turbo. Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2748464 Share on other sites More sharing options...
342Four Posted December 13, 2006 Share Posted December 13, 2006 yes - yes they are (unless they have been modified and had turbo(s) added) GTS's you mean anyway - never heard of a GST Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2748494 Share on other sites More sharing options...
SkyKC Posted December 13, 2006 Author Share Posted December 13, 2006 id hazzard a guess at it meaning you have slip on your wheels and its moving power to the fronts. Does your FW Tourque gauge go up at all? Thanks heaps Guys, By the way I dont have a FW Tourque gauge. I have a after market E-TS, not usre how it works though, currently its set up tp 50/50., when I take a turn or something on the display can see its shows 0.4 or 0.7, when Im driving straight it normaly goes from 0.0 to 0.2 Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2748619 Share on other sites More sharing options...
SAGTS-4 Posted December 14, 2006 Share Posted December 14, 2006 what does the 4WD LED mean? Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2750941 Share on other sites More sharing options...
R-SPEC Posted December 14, 2006 Share Posted December 14, 2006 tells ya when there somethin wrong with your 4wd system if it keeps lighting up you should get the 4wd system checked out. Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2751118 Share on other sites More sharing options...
HolyEvil Posted December 14, 2006 Share Posted December 14, 2006 what does the 4WD LED mean? I read on the board that when 4WD light is on..you are running only as a RWD.. if it lightsup constantly.. i have no idea how to fix it.. lol.. it's all in the threads that I've read here on the board.. hmm I have a GT-4.. hopefully my slip led never has to come on.. cheers Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2751139 Share on other sites More sharing options...
HolyEvil Posted December 14, 2006 Share Posted December 14, 2006 what does the 4WD LED mean? check this thread out =) http://www.skylinesaustralia.com/forums/in...howtopic=110502 Link to comment https://www.sau.com.au/forums/topic/145992-what-is-slip-led-indicator-on-dashboard-means/#findComment-2751231 Share on other sites More sharing options...
