Anyone know how to adjust the R34 headlights after they've been complianced and had the HID bulbs taken out of them?
I'm assuming it's a simple screw adjustment but where? Maybe these don't work once the compliance places have finished stuffing around? I've tried the obvious one sitting to the outside of the headlight moulding just before the front fender starts (clearly visible in the photos), with no effect.
My low-beams are aimed too low which makes driving on a dark night a little dodgy.
I'm attached some photos from above and one of the inside of the driver's side low-beam. Any help much appreciated thanks!!!
https://www.sau.com.au/forums/topic/146281-r34-post-compliance-headlights/
The headlights up down switch doesn't work anymore?
Yeah I was gonna ask tht question too...34s have a switch right of the steering wheel underneath..allows u to adjust the beams 3 levels...guess if you're asking this means ur switch probably doesn't work or is non existent?
yep it's gone - just a hole in the dash where it used to be... :D
i'm assuming there must be some manual way of adjusting the beam - surely this isn't legal to be complianced without some form of adjustment??
i still have the switch but it doesnt work.. also my headlights are HID im pretty sure (there bright white/blue) so does that mean they actually put some money in during compliance and stuck good bulbs back in?
I'm not 100% sure of this myself, but from what I've been told is that (in NSW at least) the adjustability of the xenon headlights are the reason for the defect (thus removed at compliancing) as it is manually controlled.
The reason that cars like BMW's can have them is because the headlights automatically dip & adjust themselves when the car is carrying extra load eg. rear passengers & cargo in the boot.
All I know is that my headlights are the originals & the switch still works ;)
Edited by Yo-Yo
Xenon lights on ADR-compliant cars must have auto-levelling to prevent dazzle, and washers, as these types of bulbs have a reduced effectiveness proportionally greater than halogen-type lights when the lights are dirty. So compliancers take them out - usually! :ninja:
I've still got my control switch thingy in the dash and it works too :)
However, I wouldn't rely on that to bring your headlights up enough anyway..I still had to manually adjust them and the switch just gives a little more control on top.
Look for a white plastic hex shaped knob, that where you adjust it from.
Turn it and the light will aim up or down.
(this is on the normal HID, should be the same though)
could you point out on the pics where this knob should be? i've had a pretty hard look under there and it's not making itself obvious.... :)
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
