yer already in it :wave:
or try svd which kym the pres resides on here sometimes too..
http://www.svd.asn.au/
ok lol :sick: Well if this is a full blown club etc, can i get any stickers for my car of Skylinesaustralia etc
SVD is now defunct and does not conduct meetings or cruises anymore... I am a former member myself.
i noticed that cos i just checked out there website and there is nothing there reali! so is this it as far as clubs in sa!?!?
Are you after registered Clubs or online forums where ya meet for cruises??
umm well im after something to go out and have car cruises, dyno days, track days etc and jus get out there n meet other car owners etc
This is the best place pal... specially if you have a skyline!
Um i think you need to appreciate it a touch more at least things happen here, when i was in darwin there wasnt sh#t except for me and a few mates on the weekends, so yeh lol gotta remember we have lives other than our cars (well sorta work and sleep) aswell and missus's to contest with lol.
Ahh now I know where I've seen you before. You were at their BBQ last christmas weren't you? Went along myself to check it out. Nice people & all, but things were clearly falling apart for the club, which is kinda sad really.
I had thought that SA should have it's own full blown SAU club but I'd never mentioned it as I didn't want to step on the toes of SVD, didn't realise they were now gone.
There is also the Vmax club which is a part of the Sporting Car Club SA, but I don't know what they are like. Yet to check it out.
This has been discussed numerous times and general consensus has that most are happy the way things are going.
what did u expect? A scene out of F&F every friday night at some undisclosed location :D
Awww whaaat, no more F&F Fridays ?
You could always check out the Infamus car club LOL
Great place to catch up with 17 year olds in crap cars, get a befect or watch someone stack their car.
Lol.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
