Here is some updated pics of mine with the teins super streets installed...Still chasing the spoiler in the last pic if anyone has seen one or know where i can get one message me please - it is taken from another member fat34 but his came standard so he wasn't sure where to get it.
Garage Kagotani BNR34 Time Attack monster!
This is one of the most sought after demo cars in Japan, not to mention one of the fastest out there with a 57.232 around Tsukuba! Believe it or not this is actually a customer car, built to become one of the most unique BNR34s ever made. A custom built GT-style wide body kit is what sets this GT-R apart from others on the road (well not technically as its not road registered!), and it sure attracted a lot of attention at TAS 2006! The kit, unlike the majority of ill-fitting stuff out there is of excellent quality and yours for a cool million Yen.
And this was the first ride to wear these impossibly cool Rays titanium-effect wheels!:
And what lies beneath that carbon bonnet you may wonder...
A T-78 blown RB28 capable of unleashing 700 PS through an OS Giken sequential transmission
The interior is, well, spartan to say the least. Only the basics have been left untouched, what is not needed to go fast around a track has been relegated to the bin!
Had to use TE37s for rolling shots as the new Rays were only a prototype of the wrong offset and catch on the AP Racing brake calipers
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
