That looks so tough!
Might actually take off my rear wing lol
your car looks just right the way it is dude, dont do it. unless your planning on slamming it...
What happened to the front bar R-Spec?
Went back to oem?
yeah didnt like the fibreglass and got over the gtr front look. way too overdone IMO
Wicked stance there R-Spec!
thanks mate :)
  • 3 weeks later...
  • 4 weeks later...
Man I'm loving this thread, it gives me a great idea on how i want my final car to look like!!
Keeps em coming guys, their fantastic pieces of machinery!
I know I shouldn't...
But for you Blazen...
How about 2 for 1?
Springs/susp'n on the blue one since arrival have lowered the car to proper height.
Is Geoff Wheeler still in the end workshop there at Valley Heights? Used to annoy the pants off him when I had my old Triumph...
Edited by Daleo
Hi Dale,
I somehow knew Geoff from church years ago when he was in cahoots with the headmaster of J. Wycliffe HS and started off a Family Church somewhere.
I actually didn't know him well except that he had a front-end + alignment + steering workshop in one of these bays - top one I think.
He seemed very easy to get along with.
Hi Dale,
Fair enough, he used to have an amazing collection of Lotus 7's (used to punt one around Catalinaph34r.gif) and Lotus Cortina's, was a wealth of knowledge with anything BMC.worship.gifHelped me out innumerable times as an apprentice (no money), but haven't crossed paths with him for many years...
Funny the things you remember when you see a picture.
I digress, apologies for offtopic, back to the 34's!
Edited by Daleo
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
