He still owns it, I saw it being impounded a couple months or so ago, not surprising to see it on Car Sales now.
I actually saw why he got impounded lol. Was driving home from the city then I saw a unmarked pulled him over on Princes, later I asked him, he said he was caught 40km over the limit lol.
Here's some pics of mine, wheels are definitely going to be replaced with something more orgasmic to the eye. The current wheels came with the car when I got it imported from Japan, not really my cup of tea. :P
Edited by JDM34
^ ^ ^ you can be proud of that!
Bringing it along to the Megalong Valley Cruise?
Haha yeah, I'm pretty happy with it so far. Had it fully serviced a week after getting it. Only issue was with the rear wiper hose which leaks water when the rear wiper is in use. Haven't been bothered trying to get it fixed yet since I don't even use it. In regards to the Megalong Valley Cruise, I wish I could! I have work on that day. I'll definitely have to come along to one of the cruises though. Would love to see everyones Skylines. :P
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
