Some I took over the last couple of weeks.
My mate just picked up this GTR off Terry. Man the thing is a beast.
I also attended the Stagea anniversary cruise with them.
http://pics.omgtom.net/cars/gtr240911/index.php
http://pics.omgtom.net/cars/sau021011/index.php
Nice pics. Bomex looks pretty nice in black
Wasn't as low as i'd hoped, next on the to do list: decent wheels!
Nice shine man. Ride height from that photo looks nice though
Edited by wilorichie
http://pics.omgtom.n...40911/index.php
http://pics.omgtom.n...21011/index.php
Aaaah...
The makings of another great photographer!
When Matthew E. is old and can't hold his camera because of grabbing hold of his walking frame, you Tom can continue to skip here and there taking the most incredible shots! :rolleyes:
