Wow loving all the GTR's...
Here some of mine.
i still think this has to be one of the cleanest/ most well presented R34 GTR's in the country.
keep the pics coming. Also can you post up some engine bay pics
Thanks mate. I'll put some more pics up soon.
^ beautiful gtr, what rims are u running?
Thanks. there VOlk GTV. 19 by 10.5 -5
Were they a custom size or something?
-5s would work much better for me as well.
Same wheels but 19x10.5 +12 (I had 15mm bolt on spacers on the rear and it was perfect but scrubbing on bumps [outer guard])
very nice colour on ur rims....yeah i got them made custom made. had to pay extra for chrome.
i have no spacers. and it doesn't scrub at all even with full car load.
and all 4 are -5.
Agreed, I love the way you have painted the Z tune bonnet where the vents are the only carbon un painted. Its amazing what a strong off set and Z tune front end does to an R34 GTR
The white and carbon works really well, keen to see the engine bay pics for that bad boy also :)
All you guys with amazing r34 gtrs are making me jealous!!!
They all look absolutely awesome
Hehe...
Well there's a R34 GTR M-Spec waiting on the docks of Kobe bound for some lucky owner in Oz.
Great cond - great price.....
She hasn't been adopted ('er bought) yet, so......
I'll let Iron Chef Whispers tell the rest! :)
