A few quick snaps of my 34 when I got her back in April, also a couple of pics from a Bells Line run and run to Nepean River
http://imgur.com/a/oTz6K#0
Trying to find someone I know with a decent camera to get some better photos
Adam, ^^^ I'd contact MaTBoY here on SAU or through his site www.autocult.net
...and ask him when his next photoshoot is on?
He's doing a photoshoot for the OzFoz car club this Sun > rolling shots
Thanks Terry, I've seen Matt's work and it's excellent (currently have2 of his pics as my wallpaper for work)
I'm working this sunday but i'll drop him a line. Cheers
If your car had a Top Secret front lip, it would be complete.
Don't do it! Top secret diffuser looks gay on standard r34 front bar. Needs Z-tune or Top Secret bar to make it flow. I considered, but I thought it doesn't look that good imo.
Here's a pic before I sold mine :)
It will have Front and Rear Diffusers fitted over the christmas period... Should have the Nismo Vents fitted too, just gotta get them clear coated first :yes:
No fancy pics from me this time, but had to join in on the bayside blue goodness.
Just got her back from getting her bonnet, bumper and lip repainted to remove all stone chips - etc and took a few happy snaps.
Fitted replacement headlights today as well.]
One of my favorite GTR on this forum!!!
Where did you get the carbon oil cooler ducts from?
Is the fit OK, as it looks like a few gaps, but might be just the photo?
Looks great, well done.
The SP1 are such a good looking wheel.
Where did you get the replacement headlights and how much?
Mine are looking quiet old and foggy and I would love to update like you have done.
I used this guy to fix one of mine when a panel beater had drilled through the back of it slightly enough to let water in... refurb to brand new can't tell the difference between original and refurb one:
http://www.drgtr.com.au/index.php?option=com_content&view=article&id=86&Itemid=78
I get bored in my spare time so just go off on tangents and make random crap for my car.
Fitment is not perfect, because they weren't moulded from genuine plastic parts. I expected this.
With some slight mods they should almost line up across the face of the bar, only the side one might need a bit more work.
They look off because I have a plastic bar bent over the wheelie bin.
Will post up some close ups once I've fitted them to my car, the blue GTR front bar was to hack up and practice, lets hope practice makes perfect.
I don't like to idea of cutting holes in my MPIII front bar but all for a good cause. Once there fitted I'll get an oil cooler kit fitted there.
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
