anthony your GTR is one of my faves if not THE fave of mine, that yellow is just beautiful. I have this wild dream of owning a yellow GTR one day and calling it BIGBRD :woot: do you have a gallery somewhere (or other shots) of your 34? Would like a wallpaper pic!
I like what you've done to the lip of the lmgt4s.
I presume to remove rash as well.
Thanks all. Yeah Owgasm that was the plan and it turned out a lot better than Terry and I thought it would. I really liked the polished lip which was subtle but set them off nicely.
Heres some pics of mine with the new wheel stcikers.
looks good but i need to change the valve stem which is painful!
will have better pics up once its finished.
This looks mega! :thumbsup: Really like the stickers mate. You've really done well with that theme, the car looks exactly how I'd do it if I had a yellow one. Terry will tell you that I have told him several times I would have liked a yellow BNR34 :)
I haven't heard much from the new owner no, he's up north in QLD and was planning to go a bit nuts with a build but no news as such unfortunately. He is on here but doesn't post much I think.
Cheers mate, mine does get reffered to as big bird by some now haha..
dont really have a gallery, just posted up lots of pics in here scattered through various pages etc. was thinking about starting a build thread but havent, it has changed alot since i bought it, and still isnt finished, got a nismo front bar waiting to get painted, and just bought some LMGT4s (but they wont go for quite awhile yet).
i have a only a couple of wallpaper quality pics taken by someone on the putty road cruise last year, send me a PM with your email and i can send a few through.
Thanks mate, i was abit unsure once i put them on as the red valve looks really bad and out of place. i think once i get a black one on there it will be great. also got center cap adaptors for the SLs but unfortunately the only style of cap that i wanted was the flush type, and it doesnt clear the axle on the front. a little dissapointed but still happy with the result.
I need some decent pics, once the bar is painted and on might get a pro shoot done i think.
Mate, the stickers look the goods. Turned out awesome! May I ask where you sourced the nismo bar from? I have been looking for a supplier other than in japan
Thanks for the comments guys! will get better pics up once the black valves go on.
cheers, got the nismo bar from a forum member on here, just got lucky. not sure if its genuine as it has no stamp, but it looks really good and did come from japan and has a very similar look to how its made comapred to other nismo items... the test fit will tell.
Ilike those stickers man, really nice, subtle touch!
cheers mate, once the bar is on i will be in touch, will more than likely still be months away though unfortunately.
This was at the SAU VIC monthly meet last night....A genuine Nismo S tune.....Very nice
A genuine nismo s-tune? lol. This is the fake car that rocked up at the lowdown showcased in sydney. Another one brought in by extreme motorsports to go with the fake nur that other sau'ers will be familiar. I am a huge fan of genuine nismo cars but this isnt one of them. End rant
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
