What profile tyres? I had dramas when I had the same size wheels with 275/35, changed to 30 profile and was all good.. Although mine is not as low as yours..
I had 30 profile because I knew that a 35 profile had changed the overall rolling diameter especially for 285/295's.
For eg a 285/35/19 for 10.5 wide rim is 682.1mm whereas mine now is 647.6mm. Essentially, a 18x10.5 rim should manage a 300mm wide tyre with lowest profile possible at an offset of +15
This is because I didn't want to roll my guards or cut anything inside my guard either and the fact that I want to at least manage 90% of a full lock with no rub too.
Also have a look at the blue and white pic together and what seems to look like the same front bar the white one has these two bumps/fangs below the gtr badge. Is it only the original ones that have that and the ones without are fake?
Hey Dim as others have said, the front bars with the 2 'Nissan' style bumps in the front grille are replicas. The original GTR front bar from Nissan has these, though both the Nismo Ver.1 and Nismo Z-tune front bars do not have these. Some replicas (or most actually) of the Nismo Z-tune front bar don't have those bumps and are therefore 'identical' replicas, though others such as those from Bodyform Aero do have those bumps. I know for fact that the entire kit on the KSR GTR was made by Peter at Bodyform Aero. Props to him and his top notch work! - I think with the 2 bumps in the grille it is a more individual look and is a good combination of elements from the standard Nissan bar and the more aggressive styling from the the Nismo Z-tune bar.
ok yeah i see what you mean.. still confuses me a bit lol With 18's like yours ive seen is the perfect size and fitment. Ive spoken to a lot of other guys that are running 19 and there all 10.5+22 and look great, where all the guys running 19's.. +12 are having scrubbing issues.
Also, I run 19 x 10 + 20 with no scrub on full lock and I'm using 275/30R19s. I did however get a bit of touching when I had 275/35s on - my car was sitting quite low before however but once i jacked it up a bit and swapped the tyres I had/have no issues at all (it's now just sitting on 10cm from the ground). In terms of worse handling you're right. It isn't that bad for street use (you've sat in my car so you'd know!!) but its definitely rougher than 18s with more rubber. I regret selling my 18s because now I need another set (this time wider) for the track.
Also on this note, it is one of my PET PEEVES seeing for sale ads for R34 GTRs where the owner advertises a 'full z-tune bodykit' just because they have a set of Nismo/replica side skirts and rear pods!! WHAT ABOUT THE FRONT BAR, GUARDS AND HOOD?!?! How are those skirts/pods specific to the z-tune and how does only having those make it a '"full kit"??!? Some GTR owners know very little about GTRs.....
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
