Woah woah woah. I spot a boot lip Dillon. Pics please, I've been looking for one for aaaaaages.
Homemade one off ;) haha
Your car looks awesome Dillon
I love the front and side indicators, they really make the car look tough.
What offset are your rims because they are very aggressive as well.
My guess would have to be +12?
And yeah haha 18x9.5+15 and 18x10+12 its a bit of a tight fit.
At the moment the front needs to be dropped down a bit more and cambered in more.
  • Like 1
i like where EVII34 is going!!! soo nice ..borderline rocket bunny look?? maybe?!1hehe DO IT!!!
Haha indeed, front fenders will be ever so slightly rocket bunny too when I have money again :whistling:
Car is looking great Dillon.
Boot lip is quite nice, good work :)
Thanks! :DDD
Did you change your indicators? Car is looking hawt brah! :woot:
Haha keen eye bro. Yep, got clear indicators. Waiting for carbon fibre eyelids to arrive and will be installing a shiny intercooler core and taking out the Hybrid stealth one. Also getting a D1 lip from VivaGarage.
  • Like 1
Awesome process Raj.
Sounds like nice plans for the future :)
Thanks Chris. Will update with pics.. :)
At that angle, steering lock, tyre profile and stance Raj, the wheels look much bigger than 18" > congratulations!
Thanks Terry! ;)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
