where in bris can you buy a oxygen sensor for a 95 r33 gtst and how much are they?? im sitting on 13ltr\100 and car isnt reved past 3500rpm normally, only has 3 inch exhaust and a boost controller set at 9psi, so i thought id replace the oxy sensor as who knows when it was last done as it has only just been imported exc.
https://www.sau.com.au/forums/topic/146678-oxy-sensor/
Bosch EL Falcon O2 sensors are the best option, around $50 on ebay or from ford, just need to swap your plug over to the one in their now...although your economy is not too bad for a Skyline, but cant hurt to put a new one in, put one of these in last month, runs great.
http://cgi.ebay.com.au/EA-EL-FALCON-OXYGEN...1QQcmdZViewItem
Edited by chook
https://www.sau.com.au/forums/topic/146678-oxy-sensor/#findComment-2738790
To test;
start the car and put a multi meter across the wires - if it's gone then you will get a steady voltage reading of over 1v, probably 12v across all the wires.
The signal wire (not sure which colour) should be moving between 0 and 1v as it analyses the exh gases so if one of the wires is doing this then its probably fine.
https://www.sau.com.au/forums/topic/146678-oxy-sensor/#findComment-2755444
13Lt/100k's is pretty good, unless you are only doing highway driving. but if it is driving to work, an you sit in traffic a little bit, then that is pretty good.
as for the sensor, they are the same as a n15 SSS pulsar. about $110 for a direct fit NGK one from autobarn or repco.
https://www.sau.com.au/forums/topic/146678-oxy-sensor/#findComment-2755490
I went to Repco, who did not stock a O2 sensor for a 96 Nissan R33 Skyline (or the dork couldn't use his PC properly???)... however i asked for an EL Falcon one which he had as a universal 3-wire part, for $127.
I said no thanks, and will probably grab a Bosche Universal for $55 from Ebay.
https://www.sau.com.au/forums/topic/146678-oxy-sensor/#findComment-2756453
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
