  • Replies 200
Dan,
Once we have all the deposits and go to make the booking we'll post the time. It's pretty much going to be an all day event! :)
Sorry man looks like I won't be able to make it tomorrow night. I paid the $25 deposit into your account with the details supplied though. I'll have to catch up with people sometime before the event.
So this is what it looks like so far:
List:
SL33KY (Emily & Daniel + 1) Deposits taken
Bluprint deposit taken
Sinista32
CeJay
Cef11e
LTSJayce Deposit taken
Contempt deposit taken
supadan
Jai Jai (possibily)
Veilside R33 Deposit taken
Skylvia
a20089 Deposit taken
James (sorry don't know your screen name) deposit taken
TONIGHT WILL BE THE LAST NIGHT TO GET YOUR DEPOSITS IN. IF WE DON'T GET THE DEPOSITS BY SUNDAY EVENING AT THE ABSOLUTE LATEST, THE DATE WILL HAVE TO BE CHANGED UNTIL WE RECEIVE ALL DEPOSITS BECAUSE WE'RE SHORT FOR A FULL BOOKING FOR OUR TEAMS.
Well there's 15 people (need 1 more) Baaaaaaaaaaaaaaaaaconer *hint hint* lol :) if you can't EFT we will be out tonight if you need to meet up! If we can get the last few deposits tonight (I have PM'd all those who are on the list and have not paid yet) we will have our full 16! COME ON GUYS!! :laugh:
List:
Sinista32
CeJay
Cef11e Deposit taken
supadan
Jai Jai (possibily)
Skylvia
Just a quick reminder this is available to anyone it is first in best dressed so if your not on the list it doesn't mean that you can book your place on the firing line. So if you are interested just deposit your money tonight at the museum or online,
Account No 10294940
BSB 062593
Account name Daniel Young
Branch Commonwealth Bank
So first in best dressed
Just letting everyone know that from the look of it (unless some weird miracle happens) it will be the 24th of feb. If it is, all those interested in coming, would the idea of hiring a minibus or something along those lines interest youse seeing as none of us want to take our lines. I that souns good to those wanting to come at a later date and the originals please just post either a YAY or a NAY.
Just seems like the most senisble thing to do all we have to do is arrange a meet point and go from there and i think a20089 if you still up for it maybe yours as there is plenty of car space :P
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
