Hey peeps,
gotta rebuild my engine so thought i might as well do some basic mods to it.
Im going to use a KKR430 turbo with supporting harware.
My question is, will a ECU re-map suffice for ~200rwkw?
Im in Newcastle, and will be happy to travel for a GOOD tune.
Or should i just get a LTX12 :happy:
Cheers
Jay
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/
Hey peeps,
Cheers
Jay
remap will do 200kw easy.
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/#findComment-2742018
i prob should use a Z32 AFM though hey?
Any ideas for a reputable tuner??
Cheers
Jay
yeh youll need a larger afm. can also put your rb20det AFM into bigger piping, adjust the k value in the fuelmap and should work fine. may have problems with idling tho; never done it myself but heard of it.
DR Drift i believe is onto it with this sorta stuff. i have a mate who works with him nowadays who i know is damn onto it.
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/#findComment-2742040
There is a guy in Sydney wh did my remap on my old car and got good results, His name is Toshi and you can find him on these forums. There is another place called yoshitokio i think in sydney. And of course dr drift in Melbourne.
just do a search for "Toshi" "yoshitokio" and "drdrift"
Hope that helps ;)
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/#findComment-2742895
  • 3 weeks later...
I'll be back in sydney early next year :cool:
2 questions sam:
~ when will u be in adelaide next
~ on my rb20 ive got the usual pod, 3.5inch straight through cat-back exhaust, hybrid copy FMIC, and soon to have RB25 turbo, is there anything else i should look at getting before the remap?
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/#findComment-2784884
2 questions sam:
a: Not sure yet, send me an e-mail and I'll add you to my mailing list.
b: FUEL PUMP, and a good quality boost control (Turbotech FTW)
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/#findComment-2784946
hey sam
would it be worth getting a remap for only the following mods: FMIC, Turbo back exhaust, turbotech boost controller, walbro fuel pump.
dont know yet whether ill upgrade the turbo.
ABSOLUTELY
https://www.sau.com.au/forums/topic/146915-rb20det-re-map/#findComment-2785458
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
