hey, just put splitfires and NGK iridium plugs into my skyline r32 gtst which has solved my missfire problems instantly :laugh:
but my next question is about the boost the car is running.
there is an aftermarket boost gauge installed on my car (previous owner) and when im flat chat accelerating in 5th the needle goes up to about 17psi.... could this be misreading?
i havent got an aftermarket boost controller so im interested to know how the car limits its boost levels?
not real cluey on this sorta detail unfortunately, any help appreciated!
mods include: FMIC, Cat Back 3" exhaust, otherwise stock
https://www.sau.com.au/forums/topic/147229-standard-r32-boost/
Boost is regulated via the spring in the wastegate actuator. R32 GTSt's run 10psi normally but by freeing up flow in other areas (exhaust) you can gain small increases in boost.
Does it level out at 17psi? or is that all you let it get to before you freak out and shut it down?
i will check it again 2day, but off the top of my head the VAC is at about 20 on idle....
its only got the stock BOV on it (no aftermarket bleed valve), i will check bout the levelling out but yes it is a bit scary watchin the needle just keep rising.....wood be fine if i knew that the components could handle it, but like u sed it isnt exactly safe
will check back soon after lookin at a few more things 2day
Maybe check the wastegate vacuum hoses before you drive it again.. if it is rising past 17psi I don't think you actually wan't to let it do that to confirm it is a wastegate hose fallen off.. much healthier for your engine to check it first :dry:
By bleed valve I meant boost controller not BOV.
lol, well i drove it round today and tried not to push it, but i did give it a boot to check and it only goes as high as 17psi n peaks, VAC is 20 at idle....
will check the vacuum hoses n that 2moro but other than that what else could i check?
it doesnt have an aftermarket boost controller, should i maybe invest in one of these to limit the boost level?
thanx for all ur help so far guys
Bleed valve can only increase boost, can't decrease it. Sounds like you have a crack/split in your waste gate vac line acting the same way a bleed valve does. If its even remotely perished replaced it, if it gets any bigger itll boost infinitely and POP goes your motor.
What is odd though is normally the ECU will just fuel cut or the car would start misfiring badly at that sort of pressure, I really would not drive it until you have sorted the issue.
Pretty sure standard boost on an RB20DET is 10psi. Anyone want to back me up?:)
i will back you up. people look at the stock boost gauge and this yeah 7psi. the rb20 actuator doesnt open below 10psi. if you look at the gauge closely the gauge isnt measured in PSI. the gauge is in bar. 0.7bar =10.152642psi
fin... :)
Well on my aftermarket guage I get 9-10psi with only a cat back exhaust and a split dump (for some stupid reason it still has a stock front pipe and stock cat) so I would imagine it not being much more freed up than it was standard.
Have since put a Turbotech manual boost controller in and think I was hitting R&R around 14psi. I've dropped it back to 11.5-12psi and it seems to go better in the top end, doesn't come on boost as harsh though which was fun but then it didn't really go anywhere.
stock boost on a rb20 is def 10 psi!!! that is why when people buy rb25 turbos they put the actulator off the rb20 turbo to run 10 psi... def sounds like u have a split in the hose or something like that... or a faulty guage.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
