hey, just put splitfires and NGK iridium plugs into my skyline r32 gtst which has solved my missfire problems instantly :laugh:
but my next question is about the boost the car is running.
there is an aftermarket boost gauge installed on my car (previous owner) and when im flat chat accelerating in 5th the needle goes up to about 17psi.... could this be misreading?
i havent got an aftermarket boost controller so im interested to know how the car limits its boost levels?
not real cluey on this sorta detail unfortunately, any help appreciated!
mods include: FMIC, Cat Back 3" exhaust, otherwise stock
https://www.sau.com.au/forums/topic/147229-standard-r32-boost/
Boost is regulated via the spring in the wastegate actuator. R32 GTSt's run 10psi normally but by freeing up flow in other areas (exhaust) you can gain small increases in boost.
Does it level out at 17psi? or is that all you let it get to before you freak out and shut it down?
i will check it again 2day, but off the top of my head the VAC is at about 20 on idle....
its only got the stock BOV on it (no aftermarket bleed valve), i will check bout the levelling out but yes it is a bit scary watchin the needle just keep rising.....wood be fine if i knew that the components could handle it, but like u sed it isnt exactly safe
will check back soon after lookin at a few more things 2day
Maybe check the wastegate vacuum hoses before you drive it again.. if it is rising past 17psi I don't think you actually wan't to let it do that to confirm it is a wastegate hose fallen off.. much healthier for your engine to check it first :dry:
By bleed valve I meant boost controller not BOV.
lol, well i drove it round today and tried not to push it, but i did give it a boot to check and it only goes as high as 17psi n peaks, VAC is 20 at idle....
will check the vacuum hoses n that 2moro but other than that what else could i check?
it doesnt have an aftermarket boost controller, should i maybe invest in one of these to limit the boost level?
thanx for all ur help so far guys
Bleed valve can only increase boost, can't decrease it. Sounds like you have a crack/split in your waste gate vac line acting the same way a bleed valve does. If its even remotely perished replaced it, if it gets any bigger itll boost infinitely and POP goes your motor.
What is odd though is normally the ECU will just fuel cut or the car would start misfiring badly at that sort of pressure, I really would not drive it until you have sorted the issue.
Pretty sure standard boost on an RB20DET is 10psi. Anyone want to back me up?:)
i will back you up. people look at the stock boost gauge and this yeah 7psi. the rb20 actuator doesnt open below 10psi. if you look at the gauge closely the gauge isnt measured in PSI. the gauge is in bar. 0.7bar =10.152642psi
fin... :)
Well on my aftermarket guage I get 9-10psi with only a cat back exhaust and a split dump (for some stupid reason it still has a stock front pipe and stock cat) so I would imagine it not being much more freed up than it was standard.
Have since put a Turbotech manual boost controller in and think I was hitting R&R around 14psi. I've dropped it back to 11.5-12psi and it seems to go better in the top end, doesn't come on boost as harsh though which was fun but then it didn't really go anywhere.
stock boost on a rb20 is def 10 psi!!! that is why when people buy rb25 turbos they put the actulator off the rb20 turbo to run 10 psi... def sounds like u have a split in the hose or something like that... or a faulty guage.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
