Hi Guys
I have an R33 GTST and it is haven some major problems lately.I Installed the Apexi Power FC Last night and I want to take it to get dynoed and tuned but the car is running like shit. It will hunt around every now and then, It surges really bad, it feels like the engine dies and when you accelerate only the turbo opens up and the engine makes a dull machine gun sound and jerks really bad. The RPMS also drop while you accelerate and then the engine kicks back in or sometimes it will drop way down until it stalls itself. For some reason it happens on and off and I'm starting to get worried as the episodes last a minute or two and at the moment it's to hard to drive and it will happen on straights or corners just out of the blue. I was thinking it needs a new fuel pump or it's not getting enough fuel. The car will also only half accelerate, you accelerate but it's like it will hold back.I have also tried resetting the ECU and doing the Idle test. I'm running out of ideas and these episodes started last week before the ECU was put in. What is is? Please help I want my baby to run again
3" cat-back kakikomoto exhaust
Splitfire Di Ignition Coils
Hybrid Intercooler
HKS Pod Filter
Blitz Boost Gauge and Full Turbo timer
Apexi Power FC + HC
https://www.sau.com.au/forums/topic/147420-serious-help-needed/
sounds like dieing fuel pump to me.
What pump should I use. Is the Bosch 044 any good? I've read alot of highly modified cars use them. Also how amny is to many or not enough? I've seen some with 2 or 3. Any ideas would be greatly appreciated.
With your current modifications
stick to a 040 in-tank it will support 500hp and costs about $190.
An 044 is external and will cost more to connect.
PS. Before you fire up the engine can you hear
the pump priming?
the pump priming?
Yeah you can for a second or two sometimes
Edited by Shoudi
my reasoning is...
car works fine
something is changed
car runs like shit
...therefore, the reason the car runs like shit is directly related to what you changed
have you tried putting the stock ECU back in to see how it runs?
my bet is the powerFC not connected properly..
good luck
Warren.
I had an intermittant problem similar a while ago. Car would stall (almost), then run fine, then be shit again for no reason. Changed everything from AFM's to pump to CAS to wiring etc. Turned out to be the connection on the top of the PFC. Because of the centre bolt, the outer pins would lose contact as the plug rocked back and forward. Put large zip ties around the ends of the PFC and plug. See if it helps.
It was acting like this exactly 4 days before installing the PFC. I wnet through the half hour idle set up and only a little bit of black smoke comes out but when it plays up a shit load does. It had same problems a week ago with the stock ECU.
so I assume it's prob not the pfc entirely, although the symptoms may have changed a little due to the pfc settings. it sounds like an AFM to me but I don't know what the machine gun sounds are from. if it was making them only after the pfc it might be the ignition settings. either way just go back to the stock ecu and start diagnosis from there at least you have a known start point. use the self diagnostics to see if it's a sensor fault.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
