hi there,
my mushroom(air filter) has no sound of sucking air and the sound of when u release the pedal(duno how to explain). totally like a stock air box.
and just a little sound when rev it up to 5000rpm
it happen suddensly>.<
thx for help
Try taking the filter off and going for a quick drive or just revving it and see how it sounds then...
If it has changed and wasent always like that then something must be wrong... Very strange for it to change suddenly.
I used to use the UniFilter oiled foam version. Ran for about the past 6 months, make massive sucking noise...more than most.
Now I have replaced with stock airbox and hi-low filter...only can hear the spool of my turbo...
performance difference...none
Gheyness factor of the air noise...10
Now thats one less thing I can be defected for.
Um, the Kunjeng and Rasr, those were excellent posts trying to help him diagnose his problem.
I've had a hks pod before. It made massive induction noise.
For it to have suddenly stopped making that noise, there must be something wrong.
Now, I don't know how mecahnically minded you are. I have a friend who always thinks there is something wrong with his car.
Is the noise actually totally gone? or just softer? Did it just stop one day suddenly? or it's softer over time?
Bov blocked/seized or turbo blown. That's all I can think of.
If ther turbo was blown he would be making next to no power so thats deffinetly not the problem. If the blow off valve was seized there would still be induction noise but at a guess you would just get much more compressor surge flutter instead of bloww off valve noise/recirculation noise. Like i suggested try taking it for a short run with the filter removed to see if there is any difference. If there is then you know its directly related to your filter. If not then theres a change somewhere else in the system.
Deren
So there's no noise when you "release the (accelerator) pedal"?
No "pssccchhtttt" noise, when there use to be?
BOV jammed? Something to do with the BOV, or the recirculating pipe.... Pull it off, have a look.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
