hahaah thats exactly what i was thinking snowy - you're screwed if aaron got pinged.
Were there any other loudish cars there? I've heard some pretty loud alfas before.
And i think someones pulling your leg about a stroker kit.
1:53 is impressive Roy.. can't wait for PI next year.
Thanks Matt.
Actually it was a 1:52.8130 in practice.
Overall I think it was 3rd fastest for the day.
Once the sun came out, my rooted rear tyres couldn't handle the heat and I could only ever get within a few tenths.
BBGTR, what are you up to ? If I spent the big bucks on a stroker I'd be really disappointed not running a sub 1.40
The noise guy wasn't from the Alfa club. I think he works for the Island itself. Anyhow, they suck ass. It's a race track, not a suburban street.
:( I thought I saw your car at you know where with the engine out.
1.40 is fast, even with 3.1 litres. Time for a cage my friend.
See you at Calder for the twilight event.
Regards
Andrew
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
