hahaah thats exactly what i was thinking snowy - you're screwed if aaron got pinged.
Were there any other loudish cars there? I've heard some pretty loud alfas before.
And i think someones pulling your leg about a stroker kit.
1:53 is impressive Roy.. can't wait for PI next year.
Thanks Matt.
Actually it was a 1:52.8130 in practice.
Overall I think it was 3rd fastest for the day.
Once the sun came out, my rooted rear tyres couldn't handle the heat and I could only ever get within a few tenths.
BBGTR, what are you up to ? If I spent the big bucks on a stroker I'd be really disappointed not running a sub 1.40
The noise guy wasn't from the Alfa club. I think he works for the Island itself. Anyhow, they suck ass. It's a race track, not a suburban street.
:( I thought I saw your car at you know where with the engine out.
1.40 is fast, even with 3.1 litres. Time for a cage my friend.
See you at Calder for the twilight event.
Regards
Andrew
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
