Different and good!!
When I put my SAU sticket on...the bottom half of "y" came off - it ripped :P
but still managed to get it on there, Im just extra careful when washing it I dont rub it off!
Remind me J, when we get mine and go to put it on, we do it in the garage with the doors shut right? :P
As for dodgi-ness, I was helping, we went to peel both sides off to try it again, only to find it mutilates the letters... In the end, we had the dodgiest looking "M" at the end of it, hence why most of it got torn off, till someone got convinced to leave it... :)
And it's only around 1CM off centre too!
pretty unlucky...........you should see the sticker on my front windscreen, bloody massive, it's a miracle the cops haven't pulled me over for it. Speaking of which, I should really pull it off now, starting to look shit.........
Are you guys serious about graphics on the front and back windscreens being illegal.
I've got pratically my entire rear windscreen filled with a vinyl graphic (it is advertising of sorts haha), I thought it was okay to fill your rear windscreen as long as you have wing mirrors.... Thats why utes can carry loads in the back and trucks as well and that blocks your vision. As well as some sign companies are offering rear windscreen one way vision that cover the whole window.
It being illegal sounds like crap to me... When I worked in the sign industry we fill peoples rear windows heaps...
Well I haven't been hassled yet, I'm off to summernats in it so lets see what happens....
Hmmmm I was pulled over a couple of weeks ago and they didn't say anything, except told me my car was blury....
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
