haha, yep, its unavoidable :D. it can't be that bad? at least i hope not.
I got mine out a few years back, went under a general, and had all 4 out in one go. Only way to do it.
I was sweet pretty much from day one, no major swelling or bruising, just couldn't open my mouth all the way. But it all depends on how heavily impacted your teeth are, mine were fairly minor.
  • Replies 6k
Posted Images
Whilst we are on the subject I thought I'd share a little bit of information with you and explain why having your teeth pulled out hurts so much.
The first misconception is that the teeth are pulled out; I was told this only works with young children loosing their milk teeth. It was explained to me that teeth removal is a lot like removing a post from the ground. By pushing a pry bar down next to the tooth, pressure is exerted on the gum and tooth. If you push down hard enough (the whole isn’t big enough for both) something has to give, and the tooth pops up.
This explains why you feel so much force when they remove teeth, I had always wondered why I felt I was being pushed into the seat and nor pulled out of the seat.
See the the trick there Cubes is you keep the gas on till you legs and feet feel tingly, then you say...."Yup, i can still feel everything"....
Then when you slur it the 4th time "Yus....icunsillfill maaahh legzzz" is when they KNOW to turn the gas down :P
Thats when id let em shove a needle in me :)
nothing mate. will probarbly get materials to sand back the sil80 - weekend is fixing car time. yay!
ur car at boostworx atm? btw did u know that when daniel got his car tuned there, apparently hasnt even paid for it and was allowed to drive it way. ????
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
