  • Replies 6k
Posted Images
all i have to say is nothing is a bolt on kit. It took most of the afternoon - we had to run around for food/misc duties. Performance? I wouldnt have a clue, you would have to ask will that but i recall him saying is that it doesnt make a difference which i then replied its just a safety modification.
btw do you remember the name of the filler that you were going to recommend for me to use on the car - its all sanded back now. Just need to fill some dents and its ready for primer. yipee
btw will is definately serious bout upping the performance on his car sam. When i was there i discovered his pfc, fmic - which we installed and oil cooler. Didnt see any aftermarket turbs though. His getting a tune tomorrow morning supposively @ boost worx.
yeah FMICs don't improve performance - if anything they degrade performance slightly, as they make cars a little more laggy (due to the car having to pressurise a larger volume before making boost). But, they are vital if you want to up boost, and they lower the intake charge temperature to help prevent pinging.
sam, do u want a cai box for your 33? Im going to get will's cai box - the one he bought of max, and fabricate it for 33's and 32's. I inspected it when we had to remove the air filter and its looks quite easy to do as long as i can get the materials. So are you keen?
so you hooked up the pfc too? whats going to happen with the oil cooler, is he gonna sell it or hook it up?
this is the exact cai box will has. I dont know if it does any good would it wouldnt hurt having one. Andrew, would you be keen for one too for the 34? =D If so i would need your car or at least access to its engine bay. =D =D
ive got a home-made heat-shield atm, i would like a full cai box, but money is a bit scarce atm (pooling all of it towards re-build), so maybe later on
hopefully he's going to sell the oil cooler to me. Nah, the pfc isnt hooked up yet. He got george at gt autosound to install it today along with a fuel pump apparently, we were there yesterday to get a hole cut in the engine bay for the fmic and he was talking bout his appointment. Although, I dont know why he's getting/got the pfc installed though because 1/its plug and play which means its basically not hand to install even my sister can do it 2/ it would more than likely be running in limp mode until it can be tuned properly which he's getting done tomorrow at bw.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
