I've picked my self up a VG30DET BB turbo with plans to get it highflowed by gcg later on down the track. Anything over 250rwkw I'd be happy with. :(
For now I will be bolting it on with an adj. FPR (maybe injectors depends on $$) to see what she gets.
I'm expecting around 210rwkw peak some where around 5500rpm. ;)
Unfortunately I can't spend money on the highflow at the moment as I need to get the suspension and diff sorted.
The subframe bushes are nackered as is the diff, it now some times breaks out in to a single spinner when jumping on the gas in second, if it doesn't do that it breaks out in to a nasty axle tramp due to the stuffed subframe bushes. :(
Hey Cubes, below is a link to BT Revolution, they sell bushes made be Zenith Tuning. Zenith is my Brother in laws new business, making up bushes, strut braces, boot braces and guard bracing, all of which is made local, sold locally at Exhaust Technology, D1 Garage and Viva, or i guess PM me.
  • Replies 6k
Posted Images
Get them to make a strut brace that steps behind the motor similar to a VL Commodore one. :rofl:
I can then bolt it on the RB30DET. :P
Where's the link?
Sorry fella here tis,
http://www.skylinesaustralia.com/forums/sh...ighlight=zenith
You would have to ask him about making a special one for your RB30!!
do you know how much one is looking at to get a stock Skyline turbo high-flowed Joel?
My Neo turbo also has the plastic impeller - I wonder what the cost would be to change it to a steel one?
I believe steel wheels are part of the GCG highflow process.
You only want to take your turbo off once right Andrew...
thanks max for not telling me you were not coming
thanks for not having your mobile on
thanks for wasting my time (its at least 20 mins for me to get there)
its cool not to be able to make it, all you have to do is tell me, so i dont waste my time
*end rant
hey sam. Aint you lucky. Well i wont have access to the net for a while so no post whoring for me =D - im typing this from my gf's laptop. Anyways, im more than likely going to go ahead with the respray this weekend as i have the equipment all ready to be hired. Want to give me a hand? oh btw Is 17cfm rated air compressor sufficent for spray painting sam?
pete - mate any chance i can borrow that spray gun of you? or if anyone else have one i can borrow that would be much appreciated.
cheers,
dooky.
Thats not good to hear mate, hope you get better. Im suprised you able are to even sit at the computer. =D
With the car, Im going to hire the equipment - air compressor and jetfire heater. Good thing bout the place im getting it from is that sunday is free which hopefully is sufficient time to prime, sand and paint. Only thing i cant get atm is a decent spray gun which hopefully can be sourced by friday.
picked up my R34 today :rofl: - still going to be a while until it is on the road .... still haven't found a stock R34 exhaust - THERE HAS TO BE ONE SOMEWHERE IN AUSTRALIA!!!!!! /FRUSTRATED
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
