  • Replies 6k
Posted Images
You'll all get a ride sooner or later :) .... I really don't think it's as exciting as you all make out :D .... and she'll be fairly stock, so it will be no PCOTY in terms of performance!
come on, u are asking about high flow turbo in other thread :crazy:
that GCG will pull 265rwkw! :uh-huh:
Sam - nah she is not sold yet - have had a few bites, but still waiting for the right person to come along.
Chapman - I am still throwing around various ideas at the moment - but I promised Carolyn I wouldn't be spending any money on this car. So I have already broken that promise, but I don't intend to spend much more.
I am, however, worried about the fragile nature of the nylon impeller on the R34 turbo -
hence my thoughts about a GCG rebuild/high flow.
Duc - nah not yet - I have other much more important things to spend money on at this stage. Plus, those roof-mounted things are illegal to use while the car is moving - as it supposedly distracts drivers behind you. If/when I do it, they will be 2 headrest mounted screens. I am hoping to put an all-in-one double din LCD screen/TV/DVD/MP3 player in sooner or later - like this one http://www.brashimports.com.au/CA1605.htm - just have to find the money first. I am hoping to come home from Vegas after some nice winnings and it may fund this and other mods. Fingers crossed.
hahah..
Sounds like a few lines I have thrown my other half.
Here's a few. :)
I need a new motor as this one has done quite a few kays and is 13yrs old, if we want to drive interstate we should really have a reliable new motor. :(
I need a PFC as the tune isn't the best and it will stuff the motor up if we drive interstate, it will also return better fuel economy.
I need injectors as they are maxed out and its dangerous for them to be running like that, the current ones are buggered and new ones that flow better will return better fuel economy for the drive interstate.
I need a bigger turbo as this one is running at its max all the time which is going to have it blow soon, if it blows it may damage the motor and we don't want it blowing while driving interstate.
:D
yeah, unfortunately (money-wise) we are shortly going on a month-long holiday to the USA, so money isn't exactly plentiful. But you get that.
Yes, the bill for getting it on the road is climbing and climbing - but now is the best time to play with wheels/disks, exhaust etc, while it is off the road! It will have quite a few toys, you know I can't help myself! But, it's still gonna be stock *cough* *cough*
Hey guys! I got it through the group buy that GR33dy organised, for $940 delivered. It left japan on friday, got to melbourne on monday, adelaide on monday night, and arrived here yesterday, then i picked it up at lunchtime today :D only problem is i have no car to install it in :D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
