  • Replies 6k
Posted Images
You'll all get a ride sooner or later :) .... I really don't think it's as exciting as you all make out :D .... and she'll be fairly stock, so it will be no PCOTY in terms of performance!
come on, u are asking about high flow turbo in other thread :crazy:
that GCG will pull 265rwkw! :uh-huh:
Sam - nah she is not sold yet - have had a few bites, but still waiting for the right person to come along.
Chapman - I am still throwing around various ideas at the moment - but I promised Carolyn I wouldn't be spending any money on this car. So I have already broken that promise, but I don't intend to spend much more.
I am, however, worried about the fragile nature of the nylon impeller on the R34 turbo -
hence my thoughts about a GCG rebuild/high flow.
Duc - nah not yet - I have other much more important things to spend money on at this stage. Plus, those roof-mounted things are illegal to use while the car is moving - as it supposedly distracts drivers behind you. If/when I do it, they will be 2 headrest mounted screens. I am hoping to put an all-in-one double din LCD screen/TV/DVD/MP3 player in sooner or later - like this one http://www.brashimports.com.au/CA1605.htm - just have to find the money first. I am hoping to come home from Vegas after some nice winnings and it may fund this and other mods. Fingers crossed.
hahah..
Sounds like a few lines I have thrown my other half.
Here's a few. :)
I need a new motor as this one has done quite a few kays and is 13yrs old, if we want to drive interstate we should really have a reliable new motor. :(
I need a PFC as the tune isn't the best and it will stuff the motor up if we drive interstate, it will also return better fuel economy.
I need injectors as they are maxed out and its dangerous for them to be running like that, the current ones are buggered and new ones that flow better will return better fuel economy for the drive interstate.
I need a bigger turbo as this one is running at its max all the time which is going to have it blow soon, if it blows it may damage the motor and we don't want it blowing while driving interstate.
:D
yeah, unfortunately (money-wise) we are shortly going on a month-long holiday to the USA, so money isn't exactly plentiful. But you get that.
Yes, the bill for getting it on the road is climbing and climbing - but now is the best time to play with wheels/disks, exhaust etc, while it is off the road! It will have quite a few toys, you know I can't help myself! But, it's still gonna be stock *cough* *cough*
Hey guys! I got it through the group buy that GR33dy organised, for $940 delivered. It left japan on friday, got to melbourne on monday, adelaide on monday night, and arrived here yesterday, then i picked it up at lunchtime today :D only problem is i have no car to install it in :D
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
