  • Replies 6k
Posted Images
looks alright, im not keen on that front grille though. needs to be a bit lower & a different front bar & skirts. i didnt like the 05 one either until i saw a brand new one in the flesh, i got to take it for a bit of a drive too :D
hehe, its just sitting on my bedroom floor at the moment. even when i get my car back i wont be able to do anything with it, cos i'll have to save for the tuning work.
Hi
The PFC comes with a conservative tune preset, so you can plug it in and drive around before you get it tuned. It will drive better than the standard computer, and will be a lot better when you get it properly tuned later on.
I did this to my skyline and had no problems.
Hi
ok cool, ill give that a go. from what i was reading the base map isnt that good, but as long as its better than the stock one, it should be ok :D
Keep an eye on the knock reading and you will be fine.
If you find it knocks at highrpm pull 2 degree's out of the load points wot uses.
I have known a one person that had the stock base map knock due to too much ignition timing. It does run super rich so going lean is nothing to worry about. :D
    • I do like the look of these things (minus the ugly flat top surface with the text) https://rajabracing.com.au/product/nissan-rb25det-neo-intake/ Retains the OEM bottom runners, for that phat low range. If you want response king, maybe go with the Plazmaman pipe work, here's my old setup from a decade ago
    • Torque will suffer greatly, will try and find dyno difference on r34 with gt30 between stock and plazmaman short runner. like 2000-3000rpm power rdip at least. EDIT Green line is stock manifold, others is plazmaman short runner I also had a rb25 with greddy and q45 TB back in the day and was shit daily driving. Plazmaman top plenum with stock runner and DBW made it so much nicer.
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
