  • Replies 6k
Posted Images
Update on the oil..
I've found the Castrol 10w60 to be a little too thick.
WOT over 3500rpm now see's 8kg/cm2 on the stock guage. :cheers:
Idle is 3, cruise ~2000rpm is 5. Cold start max's out the guage.
Prior to the castrol i ran motul 8100 5w40.
Idle - Needle over 2, cruise ~2000rpm - 4, WOT over 4000rpm 7 (only just).
It appears to make oil pressure much much more quickly now.. 3500rpm vs 4000rpm to see its peak oil pressure.
I think this is too high personally.
4Door_sleeper, whats yours run at?
lately ive watched quite a number of movies. Movies that ive seen which i can remember of the top of my head include..........
initial d the movie - pretty average
sin city - awesome just awesome. worth the money/watching
the island - quite good
land of the living dead - quite dissapointing actually, although i wasnt expecting much
house of wax - very good
what about others, what have you guys/girls seen lately and what did u think of it?
damn that is a v.nice paint job!
Hey Sam, would you be able to paint my wheel centres in your shed? They are stripping off the chrom lip and the centres, and they should be ready to mask and paint when I get them back. Do you think it would be an easy job? Also, are heatproof paints easy to come by? Otherwise I might just get the entire wheel mirror polished. Pic attached. Also 2 pics attached of what mine would look like polished.
im sure you can do it yourself andrew. go on. there was someone on this forum who did it themselves with a spray can - i bet that put you off straight away didnt it, to his spokes much like what you do to your calipers. But if you want the silky factory coloured look, use a spray gun which i guess sam would be the one to do it. im sure he's still in Adelaide atm.
I actually do have a compressor and spray gun etc .... but have never used them. Maybe I will give it a go myself. I wonder how hard it would be to do shadow chrome - that is what I would really like for the spokes.
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
