  • Replies 6k
Posted Images
i havnt seen that one.. I will post up links to more fat vids that i find online of bike stuff... Ive found a good one of a zx10r Ripping it up on a windy road!!!! This might be more your style brendan!!!!
Its a nice ninha by the looks: :woot:
http://www.uponone.com/videos.php?id=4779
Thats the riding I do...... maybe add a few more mph tho!! LOL
Had a pretty close call on my bike today (on private property) doing about 120 -140 (ie max speed on klr 600), throttle just went dead and motor felt weird and then conked out so i let off throttle and down shifted to roll start it (must of gone down two gears or something) the rear wheel went into a compression lock for about two seconds and back came out a bit..... Damn close call...after that bike was running fine --0 it was really weird as i have never had anything like this happen b4? maybe it was just a bubble in the fuel lines or something?
Any of you bike riders had this happen to you before?
I think next time i will just hold the clutch and pull over (bit safer mez thinks!!)
happened on my zx7R, iced carbs.............. common problem with the late 90's ZXR's.
Winters weekend day, cool air, long ride, loss of engine power, down a few cogs to slow it down, lock rear wheel (where was the slipper clutch in the 90's LOL), big slide, no power, BAM on it comes with compression, black snakey all down the road (oh and black undies too). Pull to side of road and let the carbs warm up again.
Brendan this is perhaps the best street cycling vid i have ever seen: its a cut down segment of pascal on le Perlipherique ie its the highlights from a lap around paris in 12 minutes: this guy can REALLLLLYY ride!!!!!!!!!!! He defenitely has a death wish!!!!!!!
http://www.uponone.com/videos.php?id=124
WOOHOOO Got the 6.1 Hemi 300C :D in today. there are only subtle changes from the standard 5.7 (like the extra 68kw) the main thing are the 20 inch wheel with monsterous brembo brakes. I would easily get one of these beasts over a FPV or HSV. Got to say this is one of the only good things about my job :P
Can't wait to get the jeep equivelant 0-100 in 5 seconds - take that Holden a 2 tonne 4wd is faster than the GTS
Winters weekend day, cool air, long ride, loss of engine power, down a few cogs to slow it down, lock rear wheel (where was the slipper clutch in the 90's LOL), big slide, no power, BAM on it comes with compression, black snakey all down the road (oh and black undies too). Pull to side of road and let the carbs warm up again. {and change undies!} :)
i just wanted to say i walked into work this morning only to feel my right foot was soaked on the front part. it seems i have a hole in the bottom of my shoe...
on another note, i cant change my avatar pic...it keeps going bk 2 an old one that i had and it would go away...i cant change it...any have any ideas?
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
